jaw111868
#1 Posted : Friday, June 17, 2011 1:49:58 PM(UTC)
jaw111868
My fridge is not that cold A 3 on a (1-10) and my freezer is cold but not mucha 5 on (1-10). Also there is water drips on the bottom of the freezer door outside and top of fridge door outside on top
#2 Posted : Saturday, June 18, 2011 3:03:55 AM(UTC)
Need more info, fans, compressor running. Also, measure the freezer and fridg. temperatures.
jaw111868
#3 Posted : Tuesday, June 21, 2011 7:23:16 AM(UTC)
jaw111868
fans are running also compressor fridge temp 44 F freezer 5 F
jaw111868
#4 Posted : Tuesday, June 21, 2011 7:25:59 AM(UTC)
jaw111868
all is running fridge 44 f frezzer 5 F
#5 Posted : Tuesday, June 21, 2011 7:46:13 AM(UTC)
Clean the condenser fan blade and condenser coils. If it still is running constantly probably a refrigerant leak or worn compressor. A compressor running constantly will waste about $100 per month.
jaw111868
#6 Posted : Wednesday, June 22, 2011 11:45:19 AM(UTC)
jaw111868
i cleaned the fan and coils and it is still running the also the freezer fan is too It is less noisy though now what do i do. How do you know if there is a refrigerant leak,(could it be a stuck defrost timmer)?
#7 Posted : Wednesday, June 22, 2011 12:01:16 PM(UTC)
You might just have bad door gaskets. If a dollar bill is pushed between the door frame and the gasket and it can be pulled out easily, you have bad gaskets and/or a broken one under the fridg door.
If bad, sometimes you can smear vaseline on them, duck tape them shut overnight and see if that helps.
