During the spin cycle there is a high pitch squeal - sounds like a bearing is going out. The washer is level and the rubber pads are on the feet.
Hi farm
Most likely the problem with your washer is a bad drain pump.
Unfortunately I'm not able to give you more accurate advise due to the model number you provided in incorrect.
