farm
#1 Posted : Monday, November 12, 2007 7:22:46 AM(UTC)
farm
During the spin cycle there is a high pitch squeal - sounds like a bearing is going out. The washer is level and the rubber pads are on the feet.
#2 Posted : Monday, November 12, 2007 5:14:17 PM(UTC)
Hi farm
Most likely the problem with your washer is a bad drain pump.
Unfortunately I'm not able to give you more accurate advise due to the model number you provided in incorrect.
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
Belarus glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
