szawackitx
#1 Posted : Wednesday, June 15, 2011 7:46:39 PM(UTC)
szawackitx
when I turn on my oven and it starts baking about 20 mins into cooking it throws a f2 error code and shuts off I then can shut it off and hit start again whats wrong
Joe / APP Team
#2 Posted : Thursday, June 16, 2011 6:06:07 AM(UTC)
Joe / APP Team
Szawackitx,
Your F2 error code indicates, there is a temperature problem in the oven.
Since it takes 20 minutes to display, you most likely have a loose connection, or a malfunctioning oven temperature sensor,
Part number: AP2023862
At room temperature(78 dgrs.) the resistance reading across the two(2) sensor wires should be 1050 to 1100 ohms resistance.And at 350 dgrs. it should be 1650 ohms.
Good Luck,
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
F3 then F2 error code on Whirlpool Oven (Oven Repair (including Ranges and Cooktops))
by Ed070811 11/10/2013 9:23:56 AM(UTC)
f2 error code while self cleaning (Oven Repair (including Ranges and Cooktops))
by sandyg 5/12/2013 2:35:23 PM(UTC)
F2 Error code (Oven Repair (including Ranges and Cooktops))
by ccfox 7/25/2012 12:51:03 PM(UTC)
Whirlpool F2 Error code. (Oven Repair (including Ranges and Cooktops))
by polk5295 3/29/2012 6:32:11 PM(UTC)
F2 error code (Oven Repair (including Ranges and Cooktops))
by DYB 3/19/2012 1:39:19 PM(UTC)
E1 F2 error code Kitchen aid biltin oven (Oven Repair (including Ranges and Cooktops))
by fredcroy 12/6/2011 2:19:31 PM(UTC)
E6 F2 error codes (Oven Repair (including Ranges and Cooktops))
by tom o 11/30/2011 6:37:15 AM(UTC)
Kitchenaid range f3 and f2 error codes (Oven Repair (including Ranges and Cooktops))
by shane1 5/24/2011 6:44:04 PM(UTC)
kenmore microwave has f2 error code (Washer Repair)
by bobval 4/29/2011 6:00:09 PM(UTC)
Please Help!! E6 and F2 Error Codes (Oven Repair (including Ranges and Cooktops))
by mlindsey3418 11/16/2010 1:27:25 PM(UTC)
E0 F2 error code (Oven Repair (including Ranges and Cooktops))
by carapet58 11/14/2010 1:33:19 PM(UTC)
by JennaLogan 1/15/2010 6:34:36 AM(UTC)
E6 F2 error code for Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by ddelay 1/2/2010 12:06:19 PM(UTC)
F2 error code (Washer Repair)
by kayakcrzy 10/20/2009 3:04:24 PM(UTC)
