when I turn on my oven and it starts baking about 20 mins into cooking it throws a f2 error code and shuts off I then can shut it off and hit start again whats wrong
Originally Posted by: szawackitx when I turn on my oven and it starts baking about 20 mins into cooking it throws a f2 error code and shuts off I then can shut it off and hit start again whats wrong Szawackitx, Your F2 error code indicates, there is a temperature problem in the oven. Since it takes 20 minutes to display, you most likely have a loose connection, or a malfunctioning oven temperature sensor, Part number: AP2023862
At room temperature(78 dgrs.) the resistance reading across the two(2) sensor wires should be 1050 to 1100 ohms resistance.And at 350 dgrs. it should be 1650 ohms. Good Luck, :) :) :)
