Receiving F1-1 and F3-1 error codes and oven shuts down. After resetting I may be able to use it for an hour(?) if at all. Sometimes it acts like it's working yet the oven cavity remains unheated.
I have already replaced the "Short Sensor" and I think I'm now looking at a "Clock board" replacement.
Does this sound correct?????
Here are your parts Model JGS8850ADSHere are a service manual and a tech sheet http://www.servicematters.com/m...ibrary/docs/16022089.pdf http://www.servicematters.com/m...ibrary/docs/16025921.pdfAfter resetting I may be able to use it for an hour(?) if at all. Sometimes it acts like it's working yet the oven cavity remains unheated.The above does point to the board problem since it is not heating but not giving you an error. I would check a couple things 1. Run the diagnostics in the tech sheet 2. I notice that the sensor runs goes to a plug then to the board. Check that the pins in the plug are not corroded. Often just a light broen or dull silver color to them. Also check the the wires going into the pins are properly crimped 3. Not a bad idea to check the sensor with a meter but this is a long shot. After that the board rises to the top of the list as the culprit. |
THIS FORUM IS DEAD!!!!!!! |
den man:
Excellent information.
This was just the type of Information I've been searching for!!!!!
Weeks looking for a service manual! How did you find one?????
I'll let you know the results.
Thank you.
