dawirick
#1 Posted : Saturday, February 28, 2009 1:34:50 PM(UTC)
dawirick
Receiving F1-1 and F3-1 error codes and oven shuts down. After resetting I may be able to use it for an hour(?) if at all. Sometimes it acts like it's working yet the oven cavity remains unheated.
I have already replaced the "Short Sensor" and I think I'm now looking at a "Clock board" replacement.
Does this sound correct?????
#2 Posted : Sunday, March 1, 2009 5:13:18 AM(UTC)
Model JGS8850ADS
Here are a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16022089.pdf
http://www.servicematters.com/m...ibrary/docs/16025921.pdf
The above does point to the board problem since it is not heating but not giving you an error.
I would check a couple things
1. Run the diagnostics in the tech sheet
2. I notice that the sensor runs goes to a plug then to the board. Check that the pins in the plug are not corroded. Often just a light broen or dull silver color to them. Also check the the wires going into the pins are properly crimped
3. Not a bad idea to check the sensor with a meter but this is a long shot.
After that the board rises to the top of the list as the culprit.
dawirick
#3 Posted : Sunday, March 1, 2009 11:51:55 AM(UTC)
dawirick
den man:
Excellent information.
This was just the type of Information I've been searching for!!!!!
Weeks looking for a service manual! How did you find one?????
I'll let you know the results.
Thank you.
