I was wondering if anyone can help me with this. I was vacuming under the fridge behind the grill as i do every couple of months. I must have bumped the lines hat go into the water filter housing. They are now slowly driping. They look to be push in connections. I turned the water off and i am wondering if i can stop the leak in anyway, or do i need to buy a new filter housing.The filter housing is not cracked. It is just leaking where the lines go into it. Thanks
Push in on the lines first. If that does not do it, replace the filter, it is clogged, and that is why it is leaking. Tom ApplianceEducator.com
