LaDonna
#1 Posted : Friday, February 27, 2009 4:41:11 PM(UTC)
LaDonna
Just started load of clothes washer filled up and then heard a loud popping noise and then it stopped.Will not wash or spin but did pump all the water out of machine.Called to see if it was belt but no belt listed for this model any ideas what it might be.Thank You
TechnicianBrian
#2 Posted : Friday, February 27, 2009 6:51:09 PM(UTC)
TechnicianBrian
Sounds like your coupler (AP3963893) is broken. Loosen the screw on the front on each end of the control panel until it slides forward and lifts up from the front. You will find the lid switch plug which needs to be disconnected and a couple brass colored clips on each end. Remove the clips, grasp the cabinet from the front and tilt it toward you and off the base. Bottom middle is the pump held in place with a couple clips, and the motor is behind with a couple more clips, but these have screws that need to be removed. Pull the motor off and you will find the coupler, or what is left of the coupler. Replace it, then reassemble the unit and enjoy your washer.
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
