foxotis@comcast.net
#1 Posted : Friday, February 27, 2009 5:17:51 AM(UTC)
foxotis@comcast.net
This dryer has worked great until last night. There has not been a change of electric or gas supply. The drum works but there is not heat. The dryer is clean and free of lint. What could be causing this, how can this be repaired by do it yourself?
Thank-you
#2 Posted : Friday, February 27, 2009 5:05:31 PM(UTC)
You have to have a simple multimeter to perform the troubleshooting. You can find the complete instructions in one of our previous posts: http://forum.appliancepartspros...3-no-heat-gas-dryer.html
Here are the break down diagrams and the parts list for the Whirlpool dryer Model LGQ9508PW1
kayakcrzy
#3 Posted : Saturday, February 28, 2009 9:06:18 AM(UTC)
kayakcrzy
Thank-you
Before you go crazy, do this first. Unplug the dryer, and take the back panel off, and there will be a white part that is about an inch and a half long, by a half inch wide. That is the thermal fuse. Pull the 2 wires off of it, and put the terminal ends together, and then tape them up, so they do not hit metal, and then plug the dryer in and see if it heats. If it does, DO NOT RUN the dryer that way. That thermal fuse is the only thing stoping the dryer from burning down the house. If it does not work, follow Gene's advise. Tom ApplianceEducator.com
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
Maytag gas dryer not heating correctly (Dryer Repair)
by ifix325 12/10/2014 6:37:45 AM(UTC)
Maytag Gas Dryer not heating (Dryer Repair)
by kimber9369 5/13/2013 10:08:17 AM(UTC)
whirlpool gas dryer not heating (Dryer Repair)
by asweetliltexan903 8/23/2012 8:51:58 AM(UTC)
by mkit83 8/5/2012 9:49:46 AM(UTC)
Admiral gas dryer not heating properly (Dryer Repair)
by moonflower23 2/4/2012 10:35:54 AM(UTC)
Maytag gas dryer not heating (Dryer Repair)
by jpono 12/11/2011 5:31:23 PM(UTC)
Admiral gas dryer not heating (Dryer Repair)
by Katnatbobchris 4/13/2011 11:13:29 AM(UTC)
by isewforu 9/17/2010 5:28:16 PM(UTC)
by woje 8/5/2010 5:43:12 PM(UTC)
whirlpool gas dryer not heating up (Dryer Repair)
by sas5417 6/19/2010 9:40:59 AM(UTC)
kenmore gas dryer not heating (Dryer Repair)
by car14 6/7/2010 12:24:12 PM(UTC)
Gas Dryer Not Heating Up (Dryer Repair)
by doolittle 2/23/2010 10:01:09 AM(UTC)
Kenmore gas dryer not heating (Dryer Repair)
by john77oh 2/19/2010 6:11:17 PM(UTC)
LG gas dryer not heating (Dryer Repair)
by strikertotheline 8/22/2009 8:36:43 PM(UTC)
