tech2tech
#1 Posted : Sunday, June 12, 2011 6:08:54 PM(UTC)
tech2tech
my gas oven will only work when the stove burner is on. If the oven is turned on by itself the orange igniter glows but the gas valve appears to not open, but as soon as I turn the top burner on it will ignite
kayakcrzy
#2 Posted : Monday, June 13, 2011 3:20:39 AM(UTC)
kayakcrzy
Replace the ignitor. The ignitor is not strong enough to open the gas valve. Tom ApplianceEducator.com
Oven wont ignite (Oven Repair (including Ranges and Cooktops))
by mjpokor 7/16/2013 8:58:40 AM(UTC)
oven wont ignite (Oven Repair (including Ranges and Cooktops))
by Ricardo25 9/3/2012 6:42:52 PM(UTC)
oven wont ignite after replacing ignitor (Oven Repair (including Ranges and Cooktops))
by tim3768 8/14/2012 2:42:06 PM(UTC)
KitchenAid Gas Oven Wont Ignite (Oven Repair (including Ranges and Cooktops))
by traveller 4/14/2011 2:51:06 PM(UTC)
gas oven wont ignite (Oven Repair (including Ranges and Cooktops))
by wkvien 1/28/2011 12:36:55 PM(UTC)
My oven wont ignite after I tightened gas leaking connector (Oven Repair (including Ranges and Cooktops))
by raminla 6/2/2010 12:14:35 PM(UTC)
Lower part of oven wont ignite (Oven Repair (including Ranges and Cooktops))
by rdanigel 8/3/2009 4:05:57 PM(UTC)
Oven wont ignite/no gas (Oven Repair (including Ranges and Cooktops))
by pavel 2/23/2008 8:07:38 AM(UTC)
by carynlee64 2/21/2008 5:58:36 PM(UTC)
by mick100 8/15/2007 8:23:04 AM(UTC)
