tech2tech
#1 Posted : 14 years ago
tech2tech
my gas oven will only work when the stove burner is on. If the oven is turned on by itself the orange igniter glows but the gas valve appears to not open, but as soon as I turn the top burner on it will ignite
kayakcrzy
#2 Posted : 14 years ago
kayakcrzy
Replace the ignitor. The ignitor is not strong enough to open the gas valve. Tom ApplianceEducator.com
Oven wont ignite (Oven Repair (including Ranges and Cooktops))
by mjpokor 12 years ago
oven wont ignite (Oven Repair (including Ranges and Cooktops))
by Ricardo25 13 years ago
oven wont ignite after replacing ignitor (Oven Repair (including Ranges and Cooktops))
by tim3768 13 years ago
KitchenAid Gas Oven Wont Ignite (Oven Repair (including Ranges and Cooktops))
by traveller 14 years ago
gas oven wont ignite (Oven Repair (including Ranges and Cooktops))
by wkvien 14 years ago
My oven wont ignite after I tightened gas leaking connector (Oven Repair (including Ranges and Cooktops))
by raminla 15 years ago
Lower part of oven wont ignite (Oven Repair (including Ranges and Cooktops))
by rdanigel 16 years ago
Oven wont ignite/no gas (Oven Repair (including Ranges and Cooktops))
by pavel 17 years ago
by carynlee64 17 years ago
by mick100 18 years ago
