ksbibb
#1 Posted : Wednesday, February 25, 2009 2:41:19 PM(UTC)
ksbibb
The dryer will not start. It beeps one time and the timer counts down. I know the door is shut becuase the lights goes out. When I open the door the light comes on, so I do not think it is the light switch.
kayakcrzy
#2 Posted : Thursday, February 26, 2009 4:44:46 AM(UTC)
kayakcrzy
Easy repair. Unplug the dryer, and then take the front off, and then you will see the lint duct. Open the dryer door, and pull the filter out, Where the filter rests inside is the lint duct. There will be a 1/4 inch screw on each side of the lint duct. Take them out and remove the duct, then you will see the thermal fuse. It is white in color. The part # is 3390719. If you want to be sure that is the problem, take the 2 wires off of the thermal fuse, and put them together with a little tape around it, so it does not hit metal, and plug it in and see if it works. If so DO NOT RUN the dryer like that. That fuse is the only thing keeping that dryer from burning down the house. Tom ApplianceEducator.com
Kenmore HE washer model#110.26002012 (Washer Repair)
by Guest 11/10/2022 1:51:26 PM(UTC)
Kenmore Heavy Duty 80 Series (Washer Repair)
by nootkabear 12/26/2021 12:58:19 PM(UTC)
Kenmore he 3T won't drain/spin, F2 (Washer Repair)
by corvairdoug 8/20/2020 2:23:35 PM(UTC)
kenmore he2 clothes still wet (Washer Repair)
by ldenorio 2/9/2020 2:55:08 PM(UTC)
Kenmore HE3t noise at beginning of wash cycle (Washer Repair)
by Brenda McAlpine 7/31/2019 10:27:42 AM(UTC)
2007 Kenmore HE2 Electric Dryer W10035050 (Dryer Repair)
by KathyMo 3/4/2019 10:28:40 AM(UTC)
Kenmore HE 3t F dl... of course (Appliance Repair Companies - East of the Mississip)
by rpcole 1/30/2019 3:42:59 PM(UTC)
Kenmore heavy duty extra capacity washer won't work (Washer Repair)
by petens 11/9/2018 1:44:47 PM(UTC)
Kenmore HE3 dryer - no heat (Dryer Repair)
by tdalton 10/2/2017 1:20:19 PM(UTC)
Kenmore HE 2plus front loader acting SCREWY! (Washer Repair)
by Hhamill1 1/22/2017 9:44:27 AM(UTC)
No Heat? Help pls. Kenmore HE2 (Dryer Repair)
by JPCyan 9/27/2016 8:02:24 PM(UTC)
Kenmore HE2 no lights (Washer Repair)
by saiber77 9/3/2016 3:46:06 PM(UTC)
kenmore he3 elite washer water temperature control (Washer Repair)
by E!iteH#3 7/24/2016 12:49:19 PM(UTC)
Brand New Kenmore HE Top load Fabric softener not dispensing (Washer Repair)
by jeffmccracken 6/10/2016 7:46:21 PM(UTC)
Kenmore HE2 Basket Removal (Washer Repair)
by Aclayttu 1/7/2016 8:48:39 PM(UTC)
