The first thing I would do is check the circuit breakers for the dryer and make sure there is 240 VAC at the power outlet. If there is nothing wrong then perform the troubleshooting, using the instructions from one of our previous posts: http://forum.appliancepartspros...timer-wont-turn-off.html and post the results. Gene.
