I am working on this air conditioner, the compressor continues to run with the unit turned off. What could be the problem?
THIS FORUM IS DEAD!!!!!!! |
:eek: This unit does not use a relay it is a Permanent Split Capacitor (PSC) compressor.
The wiring diagram does show a relay on the circuit board which I thought controlled the compressor. |
Originally Posted by: denman  The wiring diagram does show a relay on the circuit board which I thought controlled the compressor. :confused: Where I just looked again.
Page 20 in the manual near the compressor on the AC PCB Assembly, it is marked RY-COMP.
If I am out to lunch on this one could you explain what the function of this relay is Thanks in advance
denman |
Originally Posted by: denman  Page 20 in the manual near the compressor on the AC PCB Assembly, it is marked RY-COMP.
denman Yes upon further examination it is a switch (solid state) . This switch is between L2 and the overload. What purpose it serves is another question as it is not between any compressor windings.
