tlittle
#1 Posted : Wednesday, May 25, 2011 10:38:08 AM(UTC)
tlittle
when opening my dryer door, I heard metal pinging sounds falling down inside of dryer and now the door does not stop at a flat 90degree angle. It is still attached and opens and closes, however it opens to a 180degree angle. It is like a tension/spring broke?? Can I purchase the parts to repair and what parts would they be? Thank you.
magician59
#2 Posted : Wednesday, May 25, 2011 10:48:37 AM(UTC)
magician59
The door opening is controlled by two balance springs (#14 in the drawing). If you're lucky, what you heard was the springs just becoming dislodged. They will be lying inside the cabinet as you remove the front panel. If not, it will be necessary to see what part(s) may be broken.
Section replacement parts for WHIRLPOOL LER4434AW0 Residential Dryer | AppliancePartsPros.com
tlittle
#3 Posted : Wednesday, May 25, 2011 12:06:54 PM(UTC)
tlittle
:) Thank You!!!
Dryer door open light stays on (Dryer Repair)
by Guest 1/7/2022 10:07:01 AM(UTC)
Dryer Model WED5000DW2 Need help on dryer door handle (Dryer Repair)
by tljohnsonrealtor@aol.com 11/1/2018 9:44:58 AM(UTC)
Samsung dryer door seal (Dryer Repair)
by Delboule 9/16/2017 2:13:17 PM(UTC)
Dryer door will not open (Dryer Repair)
by Moandjc 9/18/2016 6:10:42 AM(UTC)
Electrolux Gas Dryer Door Open Error (Dryer Repair)
by Timbo270 1/24/2016 3:26:19 PM(UTC)
Closed Garage Door on Dryer Door (Dryer Repair)
by rhesusmonkeyboy 4/11/2014 2:40:47 PM(UTC)
intermittant dryer door switch (Dryer Repair)
by Jstanh 12/22/2013 4:43:59 PM(UTC)
Dryer door reverse kit (Dryer Repair)
by Les Kimball 6/2/2013 6:48:02 PM(UTC)
Washer (combo) quit working after removing dryer door (Washer Repair)
by RandyJ 3/21/2013 9:11:43 AM(UTC)
GE stack Dryer door switch (Dryer Repair)
by abigail17 11/14/2012 8:30:25 AM(UTC)
Dryer door pops open (Dryer Repair)
by mdavis4002 11/13/2012 3:18:34 AM(UTC)
by Martin Pollyea 9/9/2012 9:17:06 AM(UTC)
Condensation on inside of dryer door (Dryer Repair)
by TexAg156 7/29/2012 6:28:27 AM(UTC)
Dryer Door Switch (Dryer Repair)
by jtnewton 7/8/2012 7:44:31 AM(UTC)
Replace dryer door switch (Dryer Repair)
by adenise 12/7/2011 10:45:57 AM(UTC)
