Soknows
#1 Posted : 14 years ago
Soknows
This washer was installed in January 2008, by January 2010 it had problems and needed a new transmission. It just recently now stopped agitating and spinning. My husband took the cover off and the belt at the bottom was intacted and seemed functioning. What could be the problem and is it possible to fix ourselves?
Thanks for any help you can offer.
#2 Posted : 14 years ago
Remove the washer front panel. Locate the signal LED on the motor inverter. Watch its status and post the results.
Here are the breakdown diagrams and Replacement parts for General Electric WPRE6100G0WT Washer | AppliancePartsPros.com
File Attachment(s):
The signal LED location.doc (541kb) downloaded 11 time(s).
Soknows
#3 Posted : 14 years ago
Soknows
There doesn't seem to be any LED lights on ours. We've taken off the front panel and located the area same as in the picture you posted, but nothing looking like an LED light. Any ideas?
#4 Posted : 14 years ago
If there is no LED in the front of the inverter then check for it on the right side. It must be somewhere there.
Soknows
#5 Posted : 14 years ago
Soknows
I figured out how to reset it. Unplugged the machine for 2 minutes then turned it back on and pushed Start. The LED then came on. Seems to now be giving normal blinking signals. It did agitate and did spin!!! Yay!!
Not sure what happened, but for now it is working. I will try a small load in it later today.
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 9 years ago
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 10 years ago
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 12 years ago
Ge washer won't spin or agitate (Washer Repair)
by Pwat300 13 years ago
GE washer won't spin or agitate. Motor? Mode shifter? (Washer Repair)
by kzinti83 14 years ago
by mhilbeli 14 years ago
by epows68 16 years ago
ge washer won't spin or agitate (Washer Repair)
by agrimmer 16 years ago
