mjg1969
#1 Posted : Wednesday, February 4, 2009 3:00:17 PM(UTC)
mjg1969
My listed dryer will not start and just clicks. The control switch seems to work fine and rotates, lights up, and pauses. Click occurs only when I press to start. Think control board needs to be replaced but is there any part I could/should replace?
kayakcrzy
#2 Posted : Thursday, February 5, 2009 4:01:54 AM(UTC)
kayakcrzy
what you have is a bad thermal fuse. if you take off the front off the dryer, on the back bottom, left hand corner is the heating element. mounted on it is a thermal fuse, it is round with 2 wires coming to it. that will be your problem. the part # is 40113801. tom [url=]applianceeducator.com - parts[/url]
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Maytag electric dryer with coin type operation model MDE16CSAYW (Dryer Repair)
by Guest 6/29/2023 9:53:26 AM(UTC)
Maytag electric dryer question (Dryer Repair)
by cramerj 2/15/2021 4:59:49 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Maytag electric dryer takes too long. Troubleshooting guide? Service manual? (Dryer Repair)
by MargretS 11/2/2014 12:08:03 PM(UTC)
Maytag Electric Dryer Light Works But Won't Turn On (Dryer Repair)
by MaytagManNC8 4/11/2014 3:21:09 PM(UTC)
Maytag electric dryer new Thermistor going bad (Dryer Repair)
by derektuan 3/25/2014 5:59:38 PM(UTC)
Maytag electric dryer (Dryer Repair)
by anniepesathor 9/3/2013 6:31:00 AM(UTC)
Maytag electric dryer won't heat (Dryer Repair)
by kspeters 2/6/2013 5:23:47 PM(UTC)
Maytag Electric dryer (Dryer Repair)
by shulskyt 2/6/2013 1:57:13 PM(UTC)
Maytag Electric Dryer won't heat up (Dryer Repair)
by rajpat25 7/7/2012 12:56:23 PM(UTC)
maytag electric dryer runs for 10 min and shuts off (Dryer Repair)
by bearsforme_22 3/8/2012 2:02:11 AM(UTC)
