34coupe
#1 Posted : Saturday, May 21, 2011 9:48:36 AM(UTC)
34coupe
Hello,
GE side by side
I noticed the frig running constantly. Then i noticed the inside back of the freezer was iced. I defrosted the freezer and everything seemed ok for a couple of weeks. Then the same problem. No air leaks.
I have been reading thru your forum and have been well educated.
Q: If the defrost heater checks out good do I need a Main Board?
FYI I have a Haier frig also that stoped working yesterday. Went back to this site and now i am ready to order the bad start relay that u guys pointed me to. I took it apart and it rattles like a box of rocks.
Just wanted to say thanks.:)
kayakcrzy
#2 Posted : Sunday, May 22, 2011 5:08:52 AM(UTC)
kayakcrzy
If the defrost heater is good, it is usually the Motherboard. It could be 1 of the sensors, but law of averages, go with the motherboard. You could also replace the sensor too if you like. They are dirt cheap!! Tom ApplianceEducator.com
34coupe
#3 Posted : Monday, May 23, 2011 4:04:01 AM(UTC)
34coupe
kayakcrzy,
The sensor you talked about, would be the thermostat?
kayakcrzy
#4 Posted : Monday, May 23, 2011 12:41:47 PM(UTC)
kayakcrzy
#233 in the freezer section. There is usually 1 on top of the evaporator coil, and one on the bottom of the evaporator coil, and on next to the damper in the refrigerator, up top left in the back. I would go with with the board. Tom ApplianceEducator.com
34coupe
#5 Posted : Tuesday, May 24, 2011 4:15:56 AM(UTC)
34coupe
Thanks I will
Amana bottom freezer defrost problem (Refrigerator & Freezer Repair)
by bpcolll 5/29/2011 10:05:35 PM(UTC)
by gwetzler 11/6/2010 8:06:30 PM(UTC)
Freezer defrost problem (Refrigerator & Freezer Repair)
by clmyers759 11/20/2008 3:58:06 PM(UTC)
Amana frig Freezer defrost problem (Refrigerator & Freezer Repair)
by ct2023 4/8/2008 8:41:13 AM(UTC)
