gthornton
#1 Posted : Monday, February 2, 2009 8:59:55 AM(UTC)
gthornton
Ice maker on unit quit. I replaced the water valve and it worked for a week or so but has quit again. The transmitter/receiver boards check out fine. If I fill the ice maker with water manually the ice maker will freeze the water and dispense the ice but will not refill. The water source is from a water well and I suspect maybe that the ice holder tray has some deposits on it that is blocking the signal to the water valve. Dose this make sense that this could happen? If so I should be able to clean the ice maker tray and it should work, right?
thanks for the advice.
#2 Posted : Monday, February 2, 2009 5:49:48 PM(UTC)
Check the water feeding tube into the ice maker. It can be frozen.
The ice maker tray holds water and nothing else. The ice maker works by the temperature and if the temperature in the freezer is above 12°F then it will never work properly.
Also possible the ice maker itself has gone bad. Post your findings and we'll go from there.
Ice maker quit filling up-water dispenser works fine. (Refrigerator & Freezer Repair)
by Buddy Owens 8/7/2012 6:55:49 PM(UTC)
Ice Maker Quit Working (Refrigerator & Freezer Repair)
by dave2425 7/23/2012 8:45:20 AM(UTC)
ice maker quit (Refrigerator & Freezer Repair)
by tammyshoup@comcast.net 7/19/2012 7:39:25 AM(UTC)
Ice Maker Quit (Water issue?) (Refrigerator & Freezer Repair)
by Javan 8/9/2010 8:03:19 AM(UTC)
Amana Ice Maker quit working (Refrigerator & Freezer Repair)
by modelships 5/9/2010 10:41:03 AM(UTC)
Ice Maker Quit (Refrigerator & Freezer Repair)
by broke-ice 3/27/2010 9:10:58 AM(UTC)
ice maker quit on whirlpool side by side (Refrigerator & Freezer Repair)
by bgoertz 2/22/2010 12:24:51 PM(UTC)
Ice maker quit - no water or movement (Refrigerator & Freezer Repair)
by ToddCarey 2/16/2010 9:31:20 AM(UTC)
by afamador 8/11/2009 11:49:40 PM(UTC)
Kennmore ice maker quit after 1.5 years of use (Refrigerator & Freezer Repair)
by Spencer Adams 8/11/2009 5:11:54 PM(UTC)
ice maker quit working (Refrigerator & Freezer Repair)
by Bill88 7/5/2009 11:00:21 AM(UTC)
Ice maker quit working (Refrigerator & Freezer Repair)
by 647sam 6/29/2009 8:54:42 AM(UTC)
My ice maker quite working then later water dispenser doesnt work (Refrigerator & Freezer Repair)
by Marino7213 5/16/2009 7:58:17 PM(UTC)
by dustywoodz 1/28/2009 9:09:56 PM(UTC)
by jayb 12/29/2008 4:44:28 PM(UTC)
