cefore
#1 Posted : Tuesday, May 17, 2011 8:10:22 AM(UTC)
cefore
My G E TRITON XL died a couple of weeks ago...no water in.:(
To date, I've replaced The valve (at the faucet), the hose going ti the dishwasher, the inlet valve, the Flood Switch Assembly, and the Control module...all to no avail...I've rechecked continuity of the Flood Switch, checked the door switches, and all seems to be correct, but still can't get water to flow on start - up.
Help would be appreciated here!
cefore
#2 Posted : Monday, May 23, 2011 2:47:36 PM(UTC)
cefore
Finally got back to troubleshooting...I have no voltage at the inlet solenoid...is this the control module?
#3 Posted : Monday, May 23, 2011 7:32:13 PM(UTC)
I'm assuming the dishwasher was On at the test time. If you want to be sure the power was send to the water inlet valve, it's better to activate it using Service Mode. The instructions are attached.
Disconnect the wires from the water inlet valve and measure the voltage between each wire and the ground chassis. The 120 VAC reading should be on the wire which comes from the flood switch and the other wire is neutral.
Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric GSD6660G02SS Dishwasher | AppliancePartsPros.com
File Attachment(s):
Triton XL dishwashers - Service Mode.doc (211kb) downloaded 16 time(s).
cefore
#4 Posted : Wednesday, June 1, 2011 10:09:53 AM(UTC)
cefore
The situation is this...I found another bad Flood Switch, which I replaced, applied power, attempted a start...the SWITCH blew!...I'd love to check wiring, but, where can I get a schematic?:(
#5 Posted : Wednesday, June 1, 2011 2:31:37 PM(UTC)
...the SWITCH blew!...(
Can you explain it more detailed?
Did you use the Service Mode?
Did you check the voltage?
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 5/15/2022 6:57:18 AM(UTC)
GE Potscrubber-no water in-changed usual suspects (Dishwasher Repair)
by parangles 10/27/2016 5:45:42 PM(UTC)
no water in cabrio (Washer Repair)
by rick8364 6/27/2015 8:36:46 AM(UTC)
GE GSD4030Z07WW Should there be no water in bottom at end of cycle ? (Dishwasher Repair)
by NC_OldGuy 3/6/2015 11:31:09 AM(UTC)
No water in - E 24, unless jiggle float switch (Dishwasher Repair)
by gjp105 4/9/2014 8:09:18 AM(UTC)
washer agitates as soon as you turn it on(with no water in it) (Washer Repair)
by bikerhaven 4/4/2013 6:59:56 AM(UTC)
ge refrigerator no water in filter or ice maker (Refrigerator & Freezer Repair)
by bferraro 12/19/2012 3:34:51 PM(UTC)
No Water in door or ice maker (Refrigerator & Freezer Repair)
by KerryG 9/10/2012 12:15:29 AM(UTC)
fridge is warm, no water in defrost pan (Refrigerator & Freezer Repair)
by jdoliver 7/7/2012 11:21:00 AM(UTC)
No water in rinse cycle (Washer Repair)
by smnweisen 6/10/2012 2:26:49 PM(UTC)
No water in ice maker (Refrigerator & Freezer Repair)
by bbeckley 5/22/2012 10:10:29 AM(UTC)
No water in icetray (Refrigerator & Freezer Repair)
by tmagolas@rogers.com 2/20/2012 11:16:12 AM(UTC)
No water in dishwasher (Dishwasher Repair)
by micnic 10/8/2011 8:43:36 AM(UTC)
Ice maker not making ice/no water in tray (Refrigerator & Freezer Repair)
by djneil1 10/2/2011 5:08:53 AM(UTC)
No water into dishwasher after pump replacment (Dishwasher Repair)
by dyzguy 6/26/2011 9:48:27 AM(UTC)
