I noticed that the LED panel for temp control does not illuminate in any function. It does beep when you push fridge or freezer temp up and down. Also temp seems good in fridge and freezer. If it were in the realm of my automotive repair expertise, I would say it is likely that the HMI Control Assembly is bad. I am looking for an opinion as there is also a HMI Control Board I need to consider. I assume the board may be good as all functions beep and the temp of the fridge seems consistant even without being able to see the LED. Any thoughts would be greatly appreciated.
This may be related. I noticed that the fridge door sits further out than the freezer door. I noticed there seems to be no vacuum control. I used to hear the fridge door being sucked tight by way of vacuum. Is this a seperate problem or related to the above. Again, thanks for any posted assistance.
All other functions, lights, ice maker, etc. work fine. Matt
