mjjhb
#1 Posted : Sunday, January 25, 2009 12:16:17 PM(UTC)
mjjhb
I noticed that the LED panel for temp control does not illuminate in any function. It does beep when you push fridge or freezer temp up and down. Also temp seems good in fridge and freezer. If it were in the realm of my automotive repair expertise, I would say it is likely that the HMI Control Assembly is bad. I am looking for an opinion as there is also a HMI Control Board I need to consider. I assume the board may be good as all functions beep and the temp of the fridge seems consistant even without being able to see the LED. Any thoughts would be greatly appreciated.
This may be related. I noticed that the fridge door sits further out than the freezer door. I noticed there seems to be no vacuum control. I used to hear the fridge door being sucked tight by way of vacuum. Is this a seperate problem or related to the above. Again, thanks for any posted assistance.
All other functions, lights, ice maker, etc. work fine.
Matt
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
mattresses for heavy people (Dryer Repair)
by kyathi5 7/26/2018 9:12:04 PM(UTC)
whats a matter wit my dryer. is it the belt? (Dryer Repair)
by k hively 10/26/2012 4:38:39 AM(UTC)
white particluate matter in water from fridge (Refrigerator & Freezer Repair)
by Chutan 7/13/2011 10:19:47 AM(UTC)
Oven burning everything no matter what I set it at. (Oven Repair (including Ranges and Cooktops))
by DDHauto 10/16/2010 8:59:09 AM(UTC)
Temp is hot or warm, no matter the switch position (Washer Repair)
by jdumas038@bellsouth.net 7/30/2010 8:59:33 AM(UTC)
Ge Burner On High No Matter What The Setting Is On (Oven Repair (including Ranges and Cooktops))
by FDAR 10/21/2009 10:45:39 AM(UTC)
Go to AutoClean no matter what I push (Dishwasher Repair)
by deej1212 10/27/2008 4:11:10 PM(UTC)
Does lightbulb brand matter? (Microwave Repair)
by tigerluv700 9/11/2008 7:53:59 AM(UTC)
