jbeers
#1 Posted : Sunday, May 8, 2011 4:10:03 PM(UTC)
jbeers
My ge quietpower, overflows in cycle. It continues to fill when I reset the unit. It drains fine all cycles through draining but it seems to never catch up. I think it is a water valve, also wondering if it could be the float switch problem?
#2 Posted : Monday, May 9, 2011 5:49:52 AM(UTC)
Replacement parts for gsd4000n10bb models | AppliancePartsPros.com
Could not find an exact match but the above will be close.
[COLOR="DarkRed"]My ge quietpower, overflows in cycle. It continues to fill when I reset the unit. [/COLOR]
Does sound like the valve is slow when closing.
[COLOR="DarkRed"]
It drains fine all cycles through draining but it seems to never catch up.[/COLOR]
These units are notorious for not draining all the way due to a bad piston and nut (Item 564 in Section2). They normally leave about an eight to a quarter inch of water in the lowest point in the tub. If it is more than this you have a drain problem.
[COLOR="DarkRed"]
I think it is a water valve, also wondering if it could be the float switch problem?[/COLOR]
You could check this by removing the kick plate.
Either remove one wire from the overflow switch or raise it's actuator (fake an overfill condition). Now try a fill if it does not fill then the overflow switch is OK.
Set the unit back to normal operation (open the door or unplug the unit if you removed a wire) and then start a fill and from underneath lift the overflow switch actuator.
If the water valve does not shut off right away but does shut off eventually then you know it is just the valve taking too long to close.
[COLOR="Red"]Be very careful as this is a live voltage test!!![/COLOR]
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
GE Quietpower 3 dishwasher leaking (Dishwasher Repair)
by ingridt 1/18/2014 11:24:08 AM(UTC)
GE Quietpower Dishwaster - incomplete draining (Dishwasher Repair)
by sdishman 11/21/2011 1:01:24 PM(UTC)
GE QuietPower2 (Dishwasher Repair)
by ArizonaRoadWarrior 3/1/2011 7:50:05 AM(UTC)
GE QuietPower 1 keeps filling when you open the door (Dishwasher Repair)
by waynonothing 12/9/2010 4:07:23 PM(UTC)
GE quietpower II (Dishwasher Repair)
by cut04001 11/30/2010 1:52:36 PM(UTC)
GE QuietPower Dishwasher will not drain 100% (Dishwasher Repair)
by kjac3585 10/18/2010 5:48:36 PM(UTC)
GE QuietPower2 No Water Fill (Dishwasher Repair)
by Michale32086 3/8/2010 8:15:43 AM(UTC)
GE QuietPower 1 won't drain. (Dishwasher Repair)
by chrislo 12/9/2009 1:09:54 PM(UTC)
GE QuietPower III (Dishwasher Repair)
by KalahariNik 11/4/2009 9:21:19 AM(UTC)
GE QuietPower 2 (Dishwasher Repair)
by jmill85 5/24/2009 5:17:50 PM(UTC)
question on ge quietpower 2 (Dishwasher Repair)
by johnzee 12/13/2008 8:39:54 PM(UTC)
GE Quietpower 3 not using rinse agent (Dishwasher Repair)
by ghillindy1 12/4/2008 1:31:29 PM(UTC)
