You have been a member since:: 10/30/2007(UTC) Posts: 6
on my side by sise whirlpool the ice maker is freezing up in the back tube area where the water comes out,,it seems as if the water slowly drips out when it shouldn't,,,how do i fix this ,,,thanks brian
You probably have a bad water solenoid in the back of fridge or low water pressure to it. I would just order a new valve by clicking on your model #
