Kenneth A.
#1 Posted : Thursday, January 22, 2009 10:11:48 AM(UTC)
Kenneth A.
Ken: I have an Amana gas dryer LG8519W2. There is gas to the valve but it does not reach the ignitor. The electrical checks out ok. There is power to both gas solenoids. The ignitor is functioning properly so I'm assuming the shared neutral used by the ignitor and solenoids is ok. I cleared out the gas orfice, there are no obstructions. Is there a volt ohm meter check that I can do to check the function of both solenoids? Is there something that could affect both solenoids at the same time?
kayakcrzy
#2 Posted : Thursday, January 22, 2009 3:57:21 PM(UTC)
kayakcrzy
If the ignitor comes on, and no gas, replace the solonoids. Tom
Kenneth A.
#3 Posted : Friday, January 23, 2009 9:04:45 AM(UTC)
Kenneth A.
Tom. Thank you for your quick response. I really appreciate it. My diagnosis was the same as yours, but is it common that both solonoids would go bad at the same time? Is there a field check to find out if the solonoids are bad before I invest in two new ones? Ken
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
