qsilver009
#1 Posted : Tuesday, May 3, 2011 5:08:52 PM(UTC)
qsilver009
the stove has 5 glass top burner with digital switch.some day all the switch turn on and has lights. some days 2 or 3 of the switch has no lights and does not work. then one day all the light on the stove goes off and the stove won't turn on now. can you help with repairing this
#2 Posted : Wednesday, May 4, 2011 5:42:58 AM(UTC)
Replacement parts for LG LRE30451SW Electric Range | AppliancePartsPros.com
Here is a service manual
LRE30451 LG Electric Range Repair Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Sorry but am not sure what your problem is.
If unit is now totally dead, the first thing to check is the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If it is just the stove-top controls then I would try cleaning the connectors.
Be sure to unplug the unit while doing this.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
LG Stove won't turn off (Oven Repair (including Ranges and Cooktops))
by azab 2/6/2013 5:10:37 PM(UTC)
LG stoven repair/code F-1 (Oven Repair (including Ranges and Cooktops))
by robert fuller 11/15/2011 12:16:39 PM(UTC)
LG stove intermittant keypad (Oven Repair (including Ranges and Cooktops))
by richappy 4/27/2009 9:47:03 AM(UTC)
