I have an LG LRE30451sw stove and one of the burners wont turn off. Please tell me what part I need to fix this
Does the display for this burner go off or it stays on? If it stays on then the problem is a bad surface element board (#2009 at the diagram). If the display goes off and only the burner stays on then the problem is a bad main control board (#2006). - The surface element board Part number: 6871W1N010B
