Stove control keypad sometimes is non-responsive. Loostened ribbon cable and sprayed with non-residue spray and it worked for a week, then failed again, but now intermittant, get worse after cooking for a while. I assume a bad keypad. Am I right?
Hi Rich, I would suspect the keypad too. I found the Service manual which might help you. Gene.
