we need to know how to get the front panel off thanks
Slide a putty knife under the top of the dryer, about 3 inches from the end, and you will hit a clip, that will release the top on that side. Then do the same on the other side. Once the top is up, rest it on the back wall. Now to remove the front, look inside the front about 4 inches down from the top on the left side is a 5/16s screw. Remove it, and the one on the other side. Then grab the front on the left side, and pull up quick and hard, and that will release it from the bottom, and do the same on the other side, and then release the wiring harness on the door swich, and you have it. Tom ApplianceEducator.com
