Valerie Hill
#1 Posted : Monday, October 29, 2007 8:34:11 AM(UTC)
Valerie Hill
We ordered and replaced the oven ignitor and it worked the first time we used the oven and won't work now. We rechecked it made sure the connections were good and accurate but it still won't light. It only works the first time when we test it.
What could be the problem?
#2 Posted : Monday, October 29, 2007 9:55:50 AM(UTC)
Hi Valerie
I need you to describe what is going on more specific. Does the igniter glows? Also I need the complete model number of the oven.
Valerie Hill
#3 Posted : Monday, October 29, 2007 3:34:17 PM(UTC)
Valerie Hill
It only glowed the first time I tried to light it and then nothing.
Model: RAB745WEA2WW
Serial#: ZV260910P
#4 Posted : Monday, October 29, 2007 3:45:24 PM(UTC)
Hi Valerie
You have to check if the power coming to the igniter when the thermostat is on. It suppose to be about 120V.
The model number you posted is incorrect. It does not come up.
gas oven ignitor cost (Oven Repair (including Ranges and Cooktops))
by Guest 10/30/2021 5:43:49 AM(UTC)
Dcs-rg-366 oven ignitor (Oven Repair (including Ranges and Cooktops))
by Guest 6/14/2021 7:44:15 AM(UTC)
oven ignitor part differences (Oven Repair (including Ranges and Cooktops))
by Bill Patterson 2/9/2021 9:21:08 AM(UTC)
Replaced oven ignitor (Oven Repair (including Ranges and Cooktops))
by Terry V. 12/6/2016 12:16:00 PM(UTC)
DCS Oven ignitor issue (Oven Repair (including Ranges and Cooktops))
by paulcoats 11/26/2016 2:53:50 PM(UTC)
Jenn Air Gas Oven Model #JGW8130ADB Oven Ignitor won't light broiler does light (Oven Repair (including Ranges and Cooktops))
by delvarela 11/11/2015 10:40:40 AM(UTC)
Changing oven ignitor (Oven Repair (including Ranges and Cooktops))
by alinaok 7/8/2014 2:46:17 PM(UTC)
No Power To Upper Oven Ignitor (Oven Repair (including Ranges and Cooktops))
by kingriver 9/14/2013 4:51:17 PM(UTC)
Gas Oven Ignitor (Oven Repair (including Ranges and Cooktops))
by cslvburns 8/15/2013 11:58:05 AM(UTC)
replaced oven ignitor and sensor, still not getting up to temp (Oven Repair (including Ranges and Cooktops))
by BSTrue 3/25/2013 3:54:50 PM(UTC)
Maytag oven ignitor not working (Oven Repair (including Ranges and Cooktops))
by glcampbell 2/18/2013 9:54:53 AM(UTC)
how to remove stubbon screws from oven ignitor (Oven Repair (including Ranges and Cooktops))
by olroy73 2/4/2013 8:05:27 AM(UTC)
How to test oven ignitor in Frigidaire oven (Oven Repair (including Ranges and Cooktops))
by Remi32 10/8/2012 4:15:23 PM(UTC)
One of 2 Oven Ignitors Glows & Lights, Other doesn't (Oven Repair (including Ranges and Cooktops))
by dachickenfarmer 9/22/2012 12:49:39 PM(UTC)
Oven Ignitor Replacement Question (Oven Repair (including Ranges and Cooktops))
by Jerryl516 7/12/2012 6:07:06 AM(UTC)
