Valerie Hill
#1 Posted : 17 years ago
Valerie Hill
We ordered and replaced the oven ignitor and it worked the first time we used the oven and won't work now. We rechecked it made sure the connections were good and accurate but it still won't light. It only works the first time when we test it.
What could be the problem?
#2 Posted : 17 years ago
Hi Valerie
I need you to describe what is going on more specific. Does the igniter glows? Also I need the complete model number of the oven.
Valerie Hill
#3 Posted : 17 years ago
Valerie Hill
It only glowed the first time I tried to light it and then nothing.
Model: RAB745WEA2WW
Serial#: ZV260910P
#4 Posted : 17 years ago
Hi Valerie
You have to check if the power coming to the igniter when the thermostat is on. It suppose to be about 120V.
The model number you posted is incorrect. It does not come up.
gas oven ignitor cost (Oven Repair (including Ranges and Cooktops))
by Guest 3 years ago
Dcs-rg-366 oven ignitor (Oven Repair (including Ranges and Cooktops))
by Guest 4 years ago
oven ignitor part differences (Oven Repair (including Ranges and Cooktops))
by Bill Patterson 4 years ago
Replaced oven ignitor (Oven Repair (including Ranges and Cooktops))
by Terry V. 8 years ago
DCS Oven ignitor issue (Oven Repair (including Ranges and Cooktops))
by paulcoats 8 years ago
Jenn Air Gas Oven Model #JGW8130ADB Oven Ignitor won't light broiler does light (Oven Repair (including Ranges and Cooktops))
by delvarela 9 years ago
Changing oven ignitor (Oven Repair (including Ranges and Cooktops))
by alinaok 11 years ago
No Power To Upper Oven Ignitor (Oven Repair (including Ranges and Cooktops))
by kingriver 12 years ago
Gas Oven Ignitor (Oven Repair (including Ranges and Cooktops))
by cslvburns 12 years ago
replaced oven ignitor and sensor, still not getting up to temp (Oven Repair (including Ranges and Cooktops))
by BSTrue 12 years ago
Maytag oven ignitor not working (Oven Repair (including Ranges and Cooktops))
by glcampbell 12 years ago
how to remove stubbon screws from oven ignitor (Oven Repair (including Ranges and Cooktops))
by olroy73 12 years ago
How to test oven ignitor in Frigidaire oven (Oven Repair (including Ranges and Cooktops))
by Remi32 13 years ago
One of 2 Oven Ignitors Glows & Lights, Other doesn't (Oven Repair (including Ranges and Cooktops))
by dachickenfarmer 13 years ago
Oven Ignitor Replacement Question (Oven Repair (including Ranges and Cooktops))
by Jerryl516 13 years ago
