All the airways are cleaned out, but it stops running after 10 min. or so on any settings.
Does the dryer also stop during an air fluff or air dry cycle as well. if it does, you most likely need a motor. All safeties, high limits on heater, are one time thermals. Once they open they will not reset, you will have to replace them to get unit running again.
