I am having a problem with a GE top-loader. It will agitate normally for a few minutes, then the motor will suddenly start operating intermittently on approx. 1/2 to 1 second cycles. If I switch over to spin, the same thing happens. If I let it set for a bit, I can get it going again, but it soon falls back into the intermittent motor problem. When the motor is operating like this, I can hear what sounds like a relay switching on and off in the motor housing. The machine has an electronic timer (not mechanical).
Any suggestions? Thanks
You have a bad motor centrifical switch. These are not replaceable so you will need to order a new motor.
Thanks! I'll get one ordered and report the results.
Update: Installed the new motor kit (motor, harness and capacitor) last night and the washer runs great! Thanks for the help Richappy.
