rmfield
#1 Posted : Sunday, October 28, 2007 3:17:31 PM(UTC)
rmfield
I am having a problem with a GE top-loader. It will agitate normally for a few minutes, then the motor will suddenly start operating intermittently on approx. 1/2 to 1 second cycles. If I switch over to spin, the same thing happens. If I let it set for a bit, I can get it going again, but it soon falls back into the intermittent motor problem. When the motor is operating like this, I can hear what sounds like a relay switching on and off in the motor housing. The machine has an electronic timer (not mechanical).
Any suggestions?
#2 Posted : Monday, October 29, 2007 3:09:43 AM(UTC)
You have a bad motor centrifical switch. These are not replaceable so you will need to order a new motor.
rmfield
#3 Posted : Monday, October 29, 2007 7:23:25 AM(UTC)
rmfield
Thanks! I'll get one ordered and report the results.
rmfield
#4 Posted : Thursday, November 1, 2007 7:01:55 PM(UTC)
rmfield
Update: Installed the new motor kit (motor, harness and capacitor) last night and the washer runs great! Thanks for the help Richappy.
