briand805
#1 Posted : Thursday, April 21, 2011 1:16:06 PM(UTC)
briand805
Hi all. I have been looking for a solution to an issue I am having and hope someone here can give assistance.
We received the roper fridge about a year and a half ago and was told it was only a few years old. . It worked great up until last month when suddenly everything was defrosted one morning.
The fans do come on when I turn the cold selection dial. However the compressor does not turn on at all.. it makes no noise.
I have cleaned everything, taken off all parts connected to compressor and shook them and can hear not rattling. I have
turned the defrost screw until it clicks and it does not turn the compressor on. The compressor
it self does not feel warm or cold to the touch.
Any advice would be great.
#2 Posted : Saturday, April 23, 2011 2:04:00 AM(UTC)
Seems like your compressor is open. To confirm, you will need to check things with a meter.
kayakcrzy
#3 Posted : Saturday, April 23, 2011 4:29:57 AM(UTC)
kayakcrzy
Let me get this straight!! Is nothing coming on? Is the fan running in the freezer? Tom ApplianceEducator.com PS Richappy-- what are you doing up so early????
#4 Posted : Saturday, April 23, 2011 5:55:26 AM(UTC)
He said the fans are running, and I always get up early to get the latest news,I use it in many ways.
#5 Posted : Saturday, April 23, 2011 6:10:32 AM(UTC)
Replacement parts for WHIRLPOOL RT18AKXKQ03 TOP-MOUNT REFRIGERATOR | AppliancePartsPros.com
See the attachment for your wiring diagram.
First check to see if power is getting to the compressor. Could be a bad wire, rare but it does happen.
Then test the compressor and it's components.
Below is a good link on how to do this.
Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
I think your unit uses a PTC for start so here is a blurb on that.
e-refrigeration.com - PTC Relays
Odds are the overload is shot or if you are unlucky the compressor.
File Attachment(s):
rt18akx.pdf (497kb) downloaded 10 time(s).
#6 Posted : Saturday, April 23, 2011 6:25:13 AM(UTC)
Have only seen one klixon fail, but have seen total burnt out wires and ptcr device, and molten metal on the start pin.
briand805
#7 Posted : Friday, April 29, 2011 1:38:40 PM(UTC)
briand805
Thanks for the replies. I picked up a replacement start, overload unit. Wiring was pretty basic and the compressor fired right up.
briand805
#8 Posted : Friday, April 29, 2011 2:56:11 PM(UTC)
briand805
well guess i spoke to soon.. The fridge was running for about an hour. then.. soon after moving the fridge back into the kitchen I hear a pop noise and the lights dim in the kitchen. Blackened plug and the compressor wont start.
All the wiring is correct.. For some reason the amp draw seems to be tripping the overload. Guy at the repair place says it sound like the compressor is bad..
