Hi all. I have been looking for a solution to an issue I am having and hope someone here can give assistance.
We received the roper fridge about a year and a half ago and was told it was only a few years old. . It worked great up until last month when suddenly everything was defrosted one morning.
The fans do come on when I turn the cold selection dial. However the compressor does not turn on at all.. it makes no noise.
I have cleaned everything, taken off all parts connected to compressor and shook them and can hear not rattling. I have turned the defrost screw until it clicks and it does not turn the compressor on. The compressor it self does not feel warm or cold to the touch.
Any advice would be great.
Seems like your compressor is open. To confirm, you will need to check things with a meter.
Let me get this straight!! Is nothing coming on? Is the fan running in the freezer? Tom ApplianceEducator.com PS Richappy-- what are you doing up so early????
He said the fans are running, and I always get up early to get the latest news,I use it in many ways.
THIS FORUM IS DEAD!!!!!!! |
Have only seen one klixon fail, but have seen total burnt out wires and ptcr device, and molten metal on the start pin.
Thanks for the replies. I picked up a replacement start, overload unit. Wiring was pretty basic and the compressor fired right up.
well guess i spoke to soon.. The fridge was running for about an hour. then.. soon after moving the fridge back into the kitchen I hear a pop noise and the lights dim in the kitchen. Blackened plug and the compressor wont start. All the wiring is correct.. For some reason the amp draw seems to be tripping the overload. Guy at the repair place says it sound like the compressor is bad..
