Hello. My freezer suddenly quit freezing. 1st noticed when the ice coming out of ice dispenser seemed to be melting. I took the cover off the coils in the freezer and there was some frosting at the bottom of the coils. The fan is running. I then took the cover off the rear of the unit & the compressor is running [very warm] and the fan is running as well next to the compressor. Is this an issue of low freon [considering the age]? If so, do you have an idea of the cost to recharge the unit? Thanks, in advance, for any help you can give me.
Scott
Took a reading inside the freezer today with my non contact thermometer today and it reads 50.7 degrees. Same as yesterday. Still frosting coils at bottom to about 4 or 5 coils up. Come on guys please help us.
Thanks Scott
Yes it sounds like a low freon problem. Also could be a partially plugged orifice. Here is a link, take aq look at the example pictures part way down the page. http://www.applianceaid.com/frig_notcold.htmlRe-filling the unit will be expensive. You have a leak somewhere so that also has to be found and repaired. Finding a slow leak may be very difficult and it may even be a compressor leak. Often it makes more sense to put the dollars toward a new unit. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Yes it sounds like a low freon problem. Also could be a partially plugged orifice. Here is a link, take aq look at the example pictures part way down the page. http://www.applianceaid.com/frig_notcold.htmlRe-filling the unit will be expensive. You have a leak somewhere so that also has to be found and repaired. Finding a slow leak may be very difficult and it may even be a compressor leak. Often it makes more sense to put the dollars toward a new unit. Thanks Denman, I really appreciate the help. I came across [luckily] a brand new Stainless SXS auctioned off from Lowe's for a ding in the cabinet for $500 so I snatched it up. After pulling the old unit out to the garage I cleaned it up and do not visibly see a leak but may not be where it can seen. Will let my nephew [he is in refrigeration] look at it to see if it is worth salvaging. But, hey, I really do Thank you for the input. Thanks a bunch buddy;)
You are welcome.
If you have the time could you post what your nephew finds. Then when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause. |
Sure will. I will catch him when he is town again. Thanks again.
