ferg689
#1 Posted : Friday, April 15, 2011 8:59:53 AM(UTC)
ferg689
Hello. My freezer suddenly quit freezing. 1st noticed when the ice coming out of ice dispenser seemed to be melting. I took the cover off the coils in the freezer and there was some frosting at the bottom of the coils. The fan is running. I then took the cover off the rear of the unit & the compressor is running [very warm] and the fan is running as well next to the compressor. Is this an issue of low freon [considering the age]? If so, do you have an idea of the cost to recharge the unit? Thanks, in advance, for any help you can give me.
Scott
ferg689
#2 Posted : Saturday, April 16, 2011 1:06:23 PM(UTC)
ferg689
Took a reading inside the freezer today with my non contact thermometer today and it reads 50.7 degrees. Same as yesterday. Still frosting coils at bottom to about 4 or 5 coils up. Come on guys please help us.
Scott
#3 Posted : Sunday, April 17, 2011 2:56:39 AM(UTC)
Yes it sounds like a low freon problem.
Also could be a partially plugged orifice.
Here is a link, take aq look at the example pictures part way down the page.
http://www.applianceaid.com/frig_notcold.html
Re-filling the unit will be expensive.
You have a leak somewhere so that also has to be found and repaired.
Finding a slow leak may be very difficult and it may even be a compressor leak.
Often it makes more sense to put the dollars toward a new unit.
ferg689
#4 Posted : Tuesday, April 19, 2011 8:59:19 AM(UTC)
ferg689
Thanks Denman, I really appreciate the help. I came across [luckily] a brand new Stainless SXS auctioned off from Lowe's for a ding in the cabinet for $500 so I snatched it up. After pulling the old unit out to the garage I cleaned it up and do not visibly see a leak but may not be where it can seen. Will let my nephew [he is in refrigeration] look at it to see if it is worth salvaging. But, hey, I really do Thank you for the input.
Thanks a bunch buddy;)
#5 Posted : Tuesday, April 19, 2011 9:50:15 AM(UTC)
You are welcome.
If you have the time could you post what your nephew finds.
Then when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
ferg689
#6 Posted : Tuesday, April 19, 2011 9:57:12 AM(UTC)
ferg689
Sure will. I will catch him when he is town again. Thanks again.
Hotpoint Freezer Not Freezing (Dishwasher Repair)
by jjacob82 10/1/2008 12:49:49 PM(UTC)
