fridge not cold - Appliance Repair Forum - Free Service from Appliance Parts Pros
frmhere2
#1 Posted : 17 years ago
frmhere2
my side by side fridge is acting strange.
1. the fridge does not get cold.
2. the freezer works.
3. also water is leaking from bottom of fridge.
yesterday i changed the auto defrost system. the freezer works but the motor continuously runs and the blower/fan (which blows the air from freezer to the fridge) is not operating at all. also before all this happened, the fridge leaked water from under and i turned the water off from its power source. help.
:D
it has now been 24 hours,
could it be that it takes time for fridge time to get cold. right now 24 hrs later, the fridge is getting cold. i have not seen the blower work, where the freezer air is forced through upper vents. i put pop in it last night and now it is cold but not cold cold.
#2 Posted : 17 years ago
Pull the back freezer panel out and check evaporator fan.If voltage to it, but it fails to run, you will need to order one by clicking on your model # above.
frmhere2
#3 Posted : 17 years ago
frmhere2
what about the water leaking from under the fridge
freezer cold,fridge not cold enough (Refrigerator & Freezer Repair)
by BSTrue 6 years ago
Fridge Not cold enough (Refrigerator & Freezer Repair)
by water101 7 years ago
Kenmore fridge not cold enough (Refrigerator & Freezer Repair)
by benbenherenow 10 years ago
Fridge not cold. Freezer ok (Refrigerator & Freezer Repair)
by PURCHIARONI@ATT.NET 10 years ago
Freezer fine, Fridge not cold (Refrigerator & Freezer Repair)
by WWats004 10 years ago
Freezer & Fridge not cold - coils cold, evap fan works but not running (Refrigerator & Freezer Repair)
by bootpdx 10 years ago
by agdodge4x4 10 years ago
Kenmore freezer cold, fridge not cold (Refrigerator & Freezer Repair)
by bc. canuck 11 years ago
SxS fridge not cold & shuts off (Refrigerator & Freezer Repair)
by 77bravo 11 years ago
Freezer frosting over, fridge not cold (Refrigerator & Freezer Repair)
by spowel007 11 years ago
Freezer And Fridge Not Cold Enough - GE Profile Arctica (Refrigerator & Freezer Repair)
by lakeober 12 years ago
Frigidaire Freezer working, Fridge not cold (Refrigerator & Freezer Repair)
by jalill 12 years ago
Freezer vents covered with ice/ fridge not cold (Refrigerator & Freezer Repair)
by amytorp 12 years ago
frezzer back freezing up- fridge not cold (Refrigerator & Freezer Repair)
by murphy7513 12 years ago
kenmore - Freezer and Fridge not cold (Refrigerator & Freezer Repair)
by srinia 12 years ago
