jim.davis4000
#1 Posted : Tuesday, April 5, 2011 12:02:46 PM(UTC)
jim.davis4000
Our Maytag washer will not drain on the normal cycle, only occasionally on the color cycle, but usually switching over to the delicate cycle will get things moving again. It seems to me it is probably the timer, as it doesn't make sense that the pump would only work on certain cycles, or that an obstruction would only appear on certain cycles. Have any others seen this particular malfunction? Thanks.
sidfink43
#2 Posted : Wednesday, April 6, 2011 5:09:17 PM(UTC)
sidfink43
If you have the same symptoms with spin then yes, I would try replacing the timer.
Maytag washer won't drain with clothes (Washer Repair)
by Guest 7/8/2021 3:20:36 PM(UTC)
Maytag washer won't drain water after cycle ends (Washer Repair)
by jasper7821 3/6/2015 11:26:44 AM(UTC)
Maytag washer won't drain (Washer Repair)
by andy65 3/29/2012 1:18:18 PM(UTC)
maytag washer won't drain (Washer Repair)
by joedylewski 2/4/2012 12:55:51 PM(UTC)
Maytag Washer won't drain when it comes to 'spin' cycle (Washer Repair)
by andyjmatthews 8/14/2011 5:01:17 PM(UTC)
Maytag Washer Won't Drain or Stop Cycling (Washer Repair)
by bardo99 5/11/2010 8:59:06 AM(UTC)
Maytag washer won't drain before spin cycle (Washer Repair)
by marklyn 2/24/2009 3:51:22 PM(UTC)
Maytag Washer won't drain (Washer Repair)
by J Tillmanns 10/7/2007 11:43:12 AM(UTC)
