andy65
#1 Posted : Thursday, March 29, 2012 1:18:18 PM(UTC)
andy65
Washer was full of water and would spin slowly but would not drain. Lifted front of washer and kind of shook it thinking maybe an airlock and it took off and spun and drained perfectly. When it filled the next time it would not drain again. Took all of clothes out and most of water and it drained and spun fine again. Would this be the drain pump or possibly a belt? I changed the main belt last year when it wouldn't spin.
#2 Posted : Thursday, March 29, 2012 2:51:13 PM(UTC)
Possible there is a floating foreign object inside the drain hoses or between the tubs. Remove the drain hose between the tub and the pump and check the hose and outlets.
It is strongly recommended to replace both belts even if only one worn out. So it maybe a good idea to replace both belts at this time. It is very important to properly adjust the pump belt tension after installation. The instructions are attached.
- The belts kit Part number: AP4011179
Here are the breakdown diagrams and Replacement parts for Maytag LAT9206BAE WASHER-TOP LOADING | AppliancePartsPros.com
File Attachment(s):
Pump belt adjustment.doc (51kb) downloaded 3 time(s).
Maytag washer won't drain with clothes (Washer Repair)
by Guest 7/8/2021 3:20:36 PM(UTC)
Maytag washer won't drain water after cycle ends (Washer Repair)
by jasper7821 3/6/2015 11:26:44 AM(UTC)
maytag washer won't drain (Washer Repair)
by joedylewski 2/4/2012 12:55:51 PM(UTC)
Maytag Washer won't drain when it comes to 'spin' cycle (Washer Repair)
by andyjmatthews 8/14/2011 5:01:17 PM(UTC)
Maytag washer won't drain (Washer Repair)
by jim.davis4000 4/5/2011 12:02:46 PM(UTC)
Maytag Washer Won't Drain or Stop Cycling (Washer Repair)
by bardo99 5/11/2010 8:59:06 AM(UTC)
Maytag washer won't drain before spin cycle (Washer Repair)
by marklyn 2/24/2009 3:51:22 PM(UTC)
Maytag Washer won't drain (Washer Repair)
by J Tillmanns 10/7/2007 11:43:12 AM(UTC)
