irened
#1 Posted : Thursday, January 8, 2009 6:02:42 AM(UTC)
irened
In the last cycle the washer did not go into a spin. My husband turned it over and there is a bunch of rubber debris there. We need a belt, but just have to find out which one will work. Can't find the owners manual and we think that the # is correct. Could you advise us as to which belt would work. Thank you!
jtowntbo5@yahoo.com
#2 Posted : Thursday, January 8, 2009 7:27:02 AM(UTC)
jtowntbo5@yahoo.com
Depending on how much older than 10 years old, the washer may not have a belt. Not sure of the exact date, Whirlpool washers went to a direct drive coupling system. If that system were to wear out, there would be rubber debris.
irened
#3 Posted : Thursday, January 8, 2009 8:41:58 AM(UTC)
irened
I'm pretty sure that the washer was bought in the mid 90's, probably around 95-96? I can't seem to locate the papers on it, since I have moved during that time. Thx
libertyappl
#4 Posted : Thursday, January 8, 2009 8:50:08 AM(UTC)
libertyappl
I think this is your model Model LA7780XSW0 which doesn't have a belt. It has a coupler, part # 285753A.
To access the inside, raise the lid (grip the sides of the top ans pull forward slightly then raise it up) and remove the outer case.
Nat
irened
#5 Posted : Saturday, January 10, 2009 10:20:59 AM(UTC)
irened
Thanks so much for all of your help. Went and picked up the part today, and it was a coupler like you said. Copied off instructions from the net as to how to replace it. Wasn't hard at all. Husband had it done in no time. Then we found out that the gears were stripped on the agitator, so we replaced them also. Works like brand new for a 17 year old Whirpool. Thanks again and I'll be sure to tell everyone about this site.
Kenmore Washer spin problem (Washer Repair)
by vlherring 1/17/2023 8:10:33 AM(UTC)
Spin problem... (Washer Repair)
by sandesmith 1/22/2018 4:59:14 PM(UTC)
whirlpool washer spin problem (Washer Repair)
by roadranger82 6/17/2017 11:13:55 AM(UTC)
Kenmore washer 80 series spin problem (Washer Repair)
by Ikisntel 5/18/2015 10:50:24 AM(UTC)
by Ikisntel 5/17/2015 11:49:40 PM(UTC)
spin problems (Washer Repair)
by dph 4/14/2015 5:58:03 AM(UTC)
Kenmore 90 series washer spin problem (Washer Repair)
by NikoletteFancy 3/26/2015 5:51:18 AM(UTC)
Spin problems (Washer Repair)
by buckman 10/6/2014 12:35:59 PM(UTC)
Amana spin problem-topload (Washer Repair)
by gordonbegone 8/25/2014 2:27:05 PM(UTC)
LG WM1814CW spin problem (Washer Repair)
by rod910 3/17/2014 3:57:40 PM(UTC)
Kenmore 90 Series spin problem, loud noise (Washer Repair)
by dy95 3/15/2014 2:56:47 PM(UTC)
Spin problem with Whirlpool washer (Washer Repair)
by trailrider1 10/13/2013 6:57:24 AM(UTC)
Tumble/Spin Problems following Broken GE Front Loader Washer (Washer Repair)
by jimhenkle 9/27/2013 7:50:43 AM(UTC)
Maytag bearing replaced, spin problem (Washer Repair)
by nobull1466 4/9/2013 3:12:59 AM(UTC)
Help me with spin problem (again) (Washer Repair)
by twentw 3/21/2013 3:16:08 PM(UTC)
