sandejud
#1 Posted : Tuesday, January 6, 2009 5:00:39 PM(UTC)
sandejud
The turntable in my microwave no longer turns when the microwave is on. It is a spacemaker XL1400
#2 Posted : Wednesday, January 7, 2009 7:46:18 PM(UTC)
Remove the bottom panel. Remove the wires from the turntable motor and check for 120VAC to the motor while the microwave is "on".
If there is proper voltage then the motor has to be replaced.
If there is no 120VAC then the problem is a bad control board.
- The part number for the turntable motor is AP2024962
- The part number for the control board is AP2026271
Here are the break down diagrams for the GE microwave Model JVM1410BC001
Microwave repair (Microwave Repair)
by Tim Swanson 11/20/2013 1:20:16 PM(UTC)
by Burde Kamath 2/11/2013 4:08:13 AM(UTC)
Is this microwave repairable (Microwave Repair)
by kalt 12/31/2012 9:41:35 AM(UTC)
Microwave Repair (Microwave Repair)
by ramara 12/4/2012 1:13:52 PM(UTC)
microwave repair help (Microwave Repair)
by dia 10/1/2012 1:08:16 PM(UTC)
by gskill@bellsouth.net 8/1/2012 3:21:05 AM(UTC)
by JO D 12/11/2011 4:17:55 AM(UTC)
by DANLUDLOW 11/28/2011 7:28:09 AM(UTC)
microwave repair (Microwave Repair)
by cking1269 11/4/2011 9:04:36 AM(UTC)
kenmore microwave repair (Microwave Repair)
by ploou 11/3/2011 10:42:00 AM(UTC)
GE microwave repair help (Microwave Repair)
by Tom in Crozet 4/28/2011 7:07:55 PM(UTC)
Microwave Repair with loud noise (Microwave Repair)
by Faith4220 12/26/2010 11:20:14 AM(UTC)
by stillyrabbit 12/22/2010 10:52:18 AM(UTC)
by bloop 11/4/2010 8:33:04 AM(UTC)
Is old microwave repairable? (Microwave Repair)
by sadiehaflinger 11/17/2009 9:51:36 AM(UTC)
