Dryer will not turn. Think it is the belt. How do you get to the belt to check and repair it?
Does the motor run? If it does not then the problem is a blown thermal fuse (#8 on the break down diagram). The thermal fuse has to be replaced together with the cycling thermostat (#6 on the break down diagram). Gene.
