red574
#1 Posted : Sunday, January 4, 2009 5:22:12 PM(UTC)
red574
When my washer goes into the spin cycle it sounds as though a bearing is going. I want to repair the washer myself but am not quite sure what parts to order. The rear bearing comes in a kit that cost $400.00. The rear support cost only $135.00. Has anyone had this same issue? What would you recommend?
Thanks,
red574
#2 Posted : Monday, January 5, 2009 3:15:13 PM(UTC)
This a duplicated thread.
Answered by denman here: http://forum.appliancepartspros...6-front-load-washer.html
maytag front loader washer model# mhwe300vf00 (Washer Repair)
by Guest 9/26/2021 9:57:51 AM(UTC)
Maytag Front Loader not dispensing bleach or fabric softner (Washer Repair)
by Ron1404 12/18/2016 3:42:55 PM(UTC)
Maytag Front Loader FH (Washer Repair)
by MyNameIsNate 8/2/2016 2:09:50 PM(UTC)
Maytag front loader washer will not extract water from clothes all the time (Washer Repair)
by jsegura525 1/1/2015 7:48:41 AM(UTC)
UNBALANCED load - Maytag front loader MAH7500AWW (Washer Repair)
by mrogge 10/1/2014 7:40:59 AM(UTC)
Maytag front loader 2000 series problem (Washer Repair)
by amarilloscout 10/11/2013 7:16:35 PM(UTC)
Maytag front Loader GFCI- 110 ground (Washer Repair)
by Laph9979 4/28/2013 4:26:12 PM(UTC)
Maytag Front Loader Burning Smell (Washer Repair)
by raj58esh 1/21/2013 4:29:30 PM(UTC)
maytag front loader won't' spin (Washer Repair)
by tpettit 12/13/2011 7:00:07 PM(UTC)
Maytag front loader control panel or motor (Washer Repair)
by astephens99 3/16/2011 2:49:12 PM(UTC)
maytag front loader door locks/slam door (Washer Repair)
by m218perez 10/21/2010 9:35:00 AM(UTC)
MayTag Front Loader fuse (Washer Repair)
by kerthialfad 6/17/2010 12:58:40 PM(UTC)
Maytag front loader FH code (Washer Repair)
by tamiwalnut 1/28/2010 1:42:29 PM(UTC)
Overheating Maytag front loader (Washer Repair)
by richappy 11/16/2008 9:13:25 AM(UTC)
maytag front loader problem (Washer Repair)
by sal.glenn 9/14/2008 7:18:49 PM(UTC)
