red574
#1 Posted : Sunday, January 4, 2009 5:27:19 PM(UTC)
red574
When my washer goes into the spin cycle it sounds as though a bearing is going. I want to repair the washer myself but am not quite sure what parts to order. The rear bearing comes in a kit that cost $400.00. The rear support cost only $135.00. Has anyone had this same issue? What would you recommend?
Thanks,
red574
#2 Posted : Monday, January 5, 2009 3:24:59 AM(UTC)
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool front load washer WFW9620HBK0 problems (Washer Repair)
by ctbirkett 8/28/2023 4:28:27 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
LTF2940FE0 FRIGIDAIRE FRONT LOAD WASHER (Washer Repair)
by Guest 9/8/2022 9:06:55 PM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
fRIDGIDAIRE AFFINITY FRONT LOAD WASHER WILL NOT STAY IN LOCK MODE (Washer Repair)
by Guest 2/21/2022 3:21:13 PM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
Samsung front load washer rotor cover hitting (Washer Repair)
by Kickerjb44 12/19/2021 3:31:57 PM(UTC)
Samsung Front Load Washer Gets Stuck at 1 Minute (Washer Repair)
by Radar314 11/12/2021 5:45:08 AM(UTC)
maytag 2000 front load washer (Washer Repair)
by crazyeyebrad 10/30/2021 7:34:44 AM(UTC)
WF56H9100AG/A2 Samsung Front Load Washer Displays 4e / LE error code (Washer Repair)
by dcgtechnologies 10/1/2021 9:38:54 PM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
