My maytag was getting stuck on the last rinse. It was adding water for 1-2 seconds, then spinning for a couple of revolutions, then added water for 1-2 secs again, repeating continually. It was filling up completely, so we checked all the hoses & found a coin blockage. Now it just continually spins without the short adding water phase.
Can someone help me?
If it's less than a year old call a authorized tech and have it checked. If you try to work on it you would void the warranty. Nat
Thanks for the advice, but we bought it at auction, so it only came with a 60 day warranty.
Can you repost your model number it should be around the opening where you put your clothes in on the washer. Nat
Hey mate, I now have the same issue, did you end up resolving your problem with your maytag? Regards Rick
