Von
#1 Posted : Sunday, January 4, 2009 10:51:32 AM(UTC)
Von
Was working fine this morning - then I tried to dispose of some more garbage and the water won't drain - it bubbles back up. I tried the reset button but that doesn't eliminate the problem. Any ideas?
magician59
#2 Posted : Monday, January 5, 2009 5:59:48 AM(UTC)
magician59
It might be clogged AND jammed. Try inserting a 1/4 inch allen wrench into the socket in the bottom center and turning back and forth to free the rotor. If that doesn't work, open up the rubber guard at the drain and shine a light into the disposer (power off!) to see if a dish rag or something may be visible. Be careful sticking your hand into the disposer: They're designed to break bones. Best to throw the breaker or unplug the machine first.
Garbage disposal not working (Garbage Disposer Repair)
by Guest 9/25/2021 4:06:35 AM(UTC)
New Garbage Disposal sparks underneath when switch is thrown (Garbage Disposer Repair)
by john flavia 12/14/2015 8:05:13 AM(UTC)
leaking garbage disposal (Garbage Disposer Repair)
by gesche444 8/11/2014 3:23:39 PM(UTC)
Monarch Garbage Disposal (Garbage Disposer Repair)
by willie2840 7/20/2013 1:40:26 PM(UTC)
GE garbage disposal jammed from potato skins (Garbage Disposer Repair)
by Clifford_boyson_iowa 1/9/2013 8:47:55 PM(UTC)
Garbage Disposal not closing (Garbage Disposer Repair)
by avidteacher1 6/26/2012 8:41:42 AM(UTC)
by jakester3 6/12/2012 5:43:27 PM(UTC)
Leaking Garbage Disposal (Garbage Disposer Repair)
by newelldj2 4/9/2012 12:40:32 PM(UTC)
garbage disposal died - won't do anything (Garbage Disposer Repair)
by mindiloo 1/31/2012 5:36:42 PM(UTC)
Stuck garbage disposal (Garbage Disposer Repair)
by DonnieMo 1/7/2012 11:24:18 AM(UTC)
Garbage disposal leaking at yhe boiiom when water is turned on (Garbage Disposer Repair)
by dsloss1 11/13/2011 11:47:44 AM(UTC)
Garbage disposal problem (Garbage Disposer Repair)
by jnfica 7/21/2011 7:19:58 PM(UTC)
Leaky garbage disposal (Garbage Disposer Repair)
by Tippsy 6/22/2011 4:59:19 AM(UTC)
garbage disposals (Garbage Disposer Repair)
by shelterpup 1/4/2011 7:42:39 PM(UTC)
kenmore garbage disposal internal leak (Garbage Disposer Repair)
by bill5506 12/27/2009 8:12:02 AM(UTC)
