Von
#1 Posted : 16 years ago
Von
Was working fine this morning - then I tried to dispose of some more garbage and the water won't drain - it bubbles back up. I tried the reset button but that doesn't eliminate the problem. Any ideas?
magician59
#2 Posted : 16 years ago
magician59
It might be clogged AND jammed. Try inserting a 1/4 inch allen wrench into the socket in the bottom center and turning back and forth to free the rotor. If that doesn't work, open up the rubber guard at the drain and shine a light into the disposer (power off!) to see if a dish rag or something may be visible. Be careful sticking your hand into the disposer: They're designed to break bones. Best to throw the breaker or unplug the machine first.
Garbage disposal not working (Garbage Disposer Repair)
by Guest 4 years ago
New Garbage Disposal sparks underneath when switch is thrown (Garbage Disposer Repair)
by john flavia 9 years ago
leaking garbage disposal (Garbage Disposer Repair)
by gesche444 11 years ago
Monarch Garbage Disposal (Garbage Disposer Repair)
by willie2840 12 years ago
GE garbage disposal jammed from potato skins (Garbage Disposer Repair)
by Clifford_boyson_iowa 12 years ago
Garbage Disposal not closing (Garbage Disposer Repair)
by avidteacher1 13 years ago
by jakester3 13 years ago
Leaking Garbage Disposal (Garbage Disposer Repair)
by newelldj2 13 years ago
garbage disposal died - won't do anything (Garbage Disposer Repair)
by mindiloo 13 years ago
Stuck garbage disposal (Garbage Disposer Repair)
by DonnieMo 13 years ago
Garbage disposal leaking at yhe boiiom when water is turned on (Garbage Disposer Repair)
by dsloss1 13 years ago
Garbage disposal problem (Garbage Disposer Repair)
by jnfica 14 years ago
Leaky garbage disposal (Garbage Disposer Repair)
by Tippsy 14 years ago
garbage disposals (Garbage Disposer Repair)
by shelterpup 14 years ago
kenmore garbage disposal internal leak (Garbage Disposer Repair)
by bill5506 15 years ago
